-   -   Mesh conversion from universal ideas format (http://www.cfd-online.com/Forums/fluent/33270-mesh-conversion-universal-ideas-format.html)
Nurul Murad March 18, 2004 20:28
I'm trying to convert mesh from universal-ideas format by using GAMBIT. The reason for doing this is because I want to run a job using the FLUENT solver by not creating the geometry and mesh from scratch using GAMBIT.
I tried the conversion initially using a small mesh file and it worked. However, when I wanted to convert a larger mesh file (around 1 million cells) it 'hanged' on me. I dont know if the problem was caused by our system here or maybe its caused by GAMBIT's inability to handle big mesh file.
I have also tried to convert the larger mesh file straight from the FLUENT solver and it worked. However the problem is that, I now have problem in specifying the boundary conditions and other parameter that I'd normally specifiy in GAMBIT b4 saving the file as a .msh file.
Is there an alternative or a better approach that I can use to convert my mesh so that it can be used in FLUENT?
Thanks for any help or suggestions.
