Mixture model in FLUENT 6.0
Old   March 24, 2004, 03:39
Default Mixture model in FLUENT 6.0
Siva
Hi friends
I am using the multiphase mixture model for studying air and fuel flow in a carburetor.The air enters the venturi and fuel enters in a separate passage through jet.The fuel enters into the venturi and then mixes with the air.Only a portion of the fuel should get vapourised.A mixture of air,fuel,fuel vapour should travel after the venturi.
But the problem i am facing is that fuel gets completely vapourised and mixes with the air and after the venturi only air is flowing.Do any of you can help me?
Thanks in advance Sivakumar
mixture model for cavitation mech5190 FLUENT 12 December 7, 2016 03:24
Mixture model validation cases Antoine Main CFD Forum 1 January 24, 2011 01:02
VOF Model or Mixture Model mems21 FLUENT 2 March 9, 2010 10:37
How to include lift forces/wall lubrication forces in the MIXTURE multiphase model? hohomm FLUENT 0 December 17, 2009 05:45
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
