FLUENT for low pressure case
Old   March 26, 2004, 12:34
Default FLUENT for low pressure case
Jim
I plan to model the air flow in the piping system using CFD. The system is under high vacuum. Can anybody tell me whether FLUENT works well for low pressure. Thanks!
Old   March 30, 2004, 12:11
Default Re: FLUENT for low pressure case
J.W.Ryu
Yes. But, I am not sure extremly low pressure is possible. I generally use Fluent for ~10torr pressure. JWR
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
pressure inlet bc in fluent nikhil FLUENT 0 June 28, 2010 16:30
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
