Home > Forums > FLUENT
gambit problem
Old   March 30, 2004, 23:52
Default gambit problem
Benny
hi all,
if there are several Volumes, and i have to create mesh for them respectively, can i unite them after creating mesh?
another question: what's difference from uniting several volumes and not uniting them? thank you!
best regards!
benny
Old   March 31, 2004, 01:50
Default Re: gambit problem
Alamgir
Hi Benny
You must have to unite all the geometry before creating mesh.
If you don't unite the volumes then each volume will be consider as separate domain/zone. So the flow field will not be the continuous. For example two separate containers placed together with two fluid and they are not mixing.......they are separated by rigid walls.
any other question?
feel free to ask.
Alamgir
Old   March 31, 2004, 10:53
mateus
Hi!
You can also mesh the volumes separatelly (what you allready did) and then separatelly define the bc on the face pairs where the two volumes unite. Each face has to be separetelly defined as wall! You can then define the face pair in fluent as periodic interface.
good luck
MATEUS
Old   April 2, 2004, 00:53
shan
what is the difference between periodic interface and coupled interface?
Thread Tools
Trackbacks are On
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 02:33
Problem with Mesh conversion Gambit msh Foam Rachid BANNARI (Bannari) OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 25 September 11, 2011 07:58
Gambit installation problem Panos FLUENT 4 March 5, 2009 23:44
Problem meshing with Gambit Adrian FLUENT 8 October 7, 2008 08:39
Startup Problem in Gambit 2.2 with WindowXP Win Win Maw FLUENT 3 January 25, 2006 12:09
