Home > Forums > FLUENT
Force report when using symmetry
Old   April 1, 2004, 15:52
Default Force report when using symmetry
Tudor Miron
Hi, I have a "feeling" that when I use symmetry when modelling flow arounf car body I get forces report as if I was using full body. Is this true or just one of those "feelings"?
Thank you Ted
Old   April 1, 2004, 16:19
Default Re: Force report when using symmetry
Zhihua
You can get a force report around the half body you simulated. The whole body force will be twice of that.
Old   April 1, 2004, 16:49
Tudor Miron
Thank you Zhihua, I do understand that whole body firce is twice of half body. BUT I'm asking does fluent report forces for half body or whole body (when using symmetry and half body model) - as I sayd I have a feeling that it does report convert force report as for full body AUTOMATICALLY! Am I all wrong here? Sure I can run a full body simulation and see/compare the results but I thought it might be a bit easyir if I just ask
Thanks Ted
Old   April 2, 2004, 16:49
Zhihua
It reports half body. If you are doubting about it, you can actually report it in two ways: 1. report force directly, 2. use integral of wall shear stress in x direction in "Report surface integrals", this way, you can actually choose the surface to be reported. This reulst should be the same as that is obtained in 1.
Thread Tools
Trackbacks are On
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Force Report help~ or maybe Custom Field Function sailor FLUENT 0 April 13, 2011 03:45
problem with pressure force report jvd FLUENT 0 August 3, 2010 02:19
Force report every iteration in unsteady flow calculation Friso Landstra FLUENT 0 October 23, 2009 07:13
Symmetry plane and force calculation Roland CFX 7 May 31, 2006 13:34
