April 2, 2004, 04:16 |
symmetry is not symmetrical!
Hi all
I have been simulating the flow of air over a symmetrical ship, and at 0 deg yaw (head-on to the wind) the flow should be symmetrical. It is not. I have tried many different meshes and adaptions, I have tried different turbulence models as well as inviscid flow, and I have re-scaled to reduce the Reynolds number. I cannot get a symmetrical flow. Any suggestions would be appreciated. Thanks. |
April 2, 2004, 06:08 |
Re: symmetry is not symmetrical!
first I'd like to ask, whether the solutions you got are well converged. It might just be that the solution slighly oscillates. Secondly - the solution will not be completely symmetrical on unstructured non-symmetrical grid due to numerical errors. So you need to think about better mesh or perhaps solution-based adaption. Third option is - if you know that the solution must be symmetrical on a physical basis, you may enforce such solution by simply generating grid for only a half of the symmetrical geometry. Hope this helps George |
April 2, 2004, 06:55 |
Thanks George
Yes the solutions are fully converged, I think the solution does oscillate slightly as a point velocity monitor shows this. The mesh is a combination of tet and hex cells, unstructured, and is not perfectly symmetrical. Solution adaptions have been done, but cannot achieve symmetry in the solution. I did wonder about the numerical errors. The solution is expected to be symmetrical and experimental validation has shown that it is, so I did think that a symmetry plane was my next move - just felt like cheating! Thanks for your help, Dave |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 14:26 |
All're symmetrical , but fluid is not symmetrical ? | urbanitylee | FLUENT | 7 | April 23, 2009 02:02 |
Forces in Symmetry | Matt | CFX | 2 | February 25, 2009 05:41 |
radiation and symmetry | Mark | FLUENT | 2 | November 4, 2004 13:50 |
