udf problem
i inquire the posibility of modeling doxin emission using fluent.
Re: udf problem
my meaning is that it is impossible to simulate other gas pollution emission (mercury)by fluent soft
Re: udf problem
You should be able to simulate almost any pollutant emission, provided you have defined the required UDS and written a proper UDF with all the chemical and physical models you need to describe the formation of the particular pollutant you are interested in (I didn't understand if you are interested in mercury or dioxines).
What kind of problems are you encountering? Regards, Ale |
Re: udf problem
Dear Ale: thank you for your information, i want to simulate the distribution of mercury during sludge combustion, i used fluent soft two years ago, however, i do not sure i can simulate the distribution of mercury by soft.if i have the code, i can finish the project.hence, i inquire the possibility, if it can simulate the distribution, then i will do. of course, i have model of formation gas mercury.
bestregard han |
Re: udf problem
Dear Ale: i find UDS is only mass flow, how to add other uds? this is my problem.
best regard han |
Re: udf problem
Han,
I think that you can do what you'd like, but It does not mean that it will be easy. It can take some time to learn writing UDF, debug, solve numerical problems and modelling issues, and so on... User Defined Scalars can be any scalar (concentration, molar or mass fraction, enthalpy...) with any unit. Mass flow rate is just the flux function that is used to solve the scalars' transport equations (this means that you should multiply by the fluid density the source terms for the scalars). I think that it would be good for you to go through the UDF manual to learn UDF features and capability, to understand what kind of effort you will need and to see if you can afford it. Best regards, Ale |
Re: udf problem
Dear Ale: After i browse the udf manual, i did not find how to add the concentration scalar in fluent. In fact, i solve this problem in china by fortan code and wrote some code about the formation and transformation of gas mercury. however, i have not the copyright of fortran code , hence i can not use the fortran code in japan, the professor in japan suggest that i use fluent soft to solve the problem. hence, i inquire you if it is possibility of finishing the work using fluent soft. if it is impossible, i would not waste my time.
Though i get some information about this problem, i did not find how do add the user define scalar in fluent soft, can you give me more information?At the same time, i write to officer of fluent corporation . best regard han |
Re: udf problem
Hi, Again: I think that it is possible to do what you would like to do, and I ask other posters to confirm or deny what I am saying.
Read more carefully the UDF User's Guide. You'll find in chapter 9 all you can need to know on User Defined Scalars Transport Modelling. You have to define the number of scalars you need (e.g. 1 scalar = 1 species concentration), and solve the corresponding transport equations. You'll never find how to add 'species concentration'...Fluent only sees scalars, no matter of what they are, it will be your care to make calculations consistent. You can define the source terms for each scalar by the macro DEFINE_SOURCE. You can use DEFINE_ADJUST to perform any calculation you need to repeat before each iteration. You should refer to the UG for further information and details. It will need some effort to learn everything you need...so, If you ask me whether it is possible to solve the problem, I would answer yes; if you ask me whether you'll solve the problem in few days or even in few weeks, I would answer maybe not. Good luck, Ale |
Re: udf problem
Dear Ale: After discuss with you and other people, i know how to finish this work and i will try my best to finish this project in several months.thank you for your help.
bestregard han |
Hello
Did you manage to solve your issue? Can you please guide me, as I am also trying to write a UDS to simulate pollutant emission per unit length. The guides/tutorials I found so far are not that clear. Thank you |
Hi mz_uon,
please review the age of this thread... Consider to describe your problem in detail on the respective subforum if you intending to use Fluent. Describe there what you have already tried, and how it failed. What did your literature research yield? It became more common over the last years to find open sources in supplementary material. Maybe your field of research is already open enough that you can find a better starting point. |
Yes, I will post it on the respective forums. Thanks |
