Operating Pressure
Old   April 7, 2004, 10:43
Default Operating Pressure
Nori
I am using the incompressible ideal gas model to simulate a cold flow. My inlet boundary conditions are using a mass flow inlet, since I know the mass flow rate and temperature. The question I have is what should be the operating pressure? I also know the inlet pressure of 446.2 psia. Shouldn't the operating pressure be 14.7psi? My friend said that it should be 446.2psia + 14.7psi for a operating pressure of 460.9psi. Is he right? I would think it would be 14.7psi for operating pressure. I am throughly confused here. I am also getting reversed flow at the outlet. I have been using outflow conditions. Would using pressure outlet stop reverse flow? I also know the outlet pressure of 424psia. Any help?
Old   April 7, 2004, 11:29
Default Re: Operating Pressure
Ale
Hi, read User's Guide 7.12
Operating pressure is the difference between the absolute and the gauge pressure, and it should be around the mean flow pressure in your case (i.e. around 435 psia).
I hope this helps,
Regards,
Ale
Operating Pressure and Cd micvm FLUENT 0 March 24, 2011 23:36
OPERATING PRESSURE manish FLUENT 6 February 25, 2011 04:40
Operating Pressure (Natural Convection problem) Andrew Tress Main CFD Forum 1 July 3, 2006 16:00
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
floating operating pressure Shankar FLUENT 1 January 30, 2004 04:08
