Home > Forums > FLUENT
UDF problem occurs in 2-CPU computer
Old   April 7, 2004, 03:52
Default UDF problem occurs in 2-CPU computer
David
Is there any difference of UDF file between in dual-CPU machine and in single CPU one? I run my case in a dual-CPU machine,but the UDF could not be loaded correctly£¬where the same case can run in single CPU machine normally.
Old   April 7, 2004, 04:46
Default Re: UDF problem occurs in 2-CPU computer
FJ
Let check the follwings.
-Windows(Linux), In UDF library directory, there is the directory named "ntx86(lnx86)" . And the below , Is there the directories named "2d_host" and "2d_node"?. Or is your UDF library made from parallel version?.
If it's not, it has to be re-compiled with parallel version.
Thank you
FJ
Old   April 7, 2004, 06:00
thomas
FJ is right, to read the library you need the build the library in parallel before. Also 2 furthers things: - make sure the macrso you use can be used in paralell. - ALso if you initiate some loops in your UDF, essentially loop over the whole domain, make sure you to use the right loop macro which makes the loop over all the nodes -> go to the udf documentation
thomas
Thread Tools
Trackbacks are On
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 32 May 8, 2015 06:05
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Pressure profile UDF for unsteady-state problem? Mohsen Keshavarzian FLUENT 2 August 20, 2008 04:22
I have problem of UDF with turbulent premx source. Z FLUENT 0 February 16, 2005 04:34
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 10:22
