April 7, 2004, 11:15 |
Accessing a zone
Hello all
Is it possible to access a particular zone in Fluent through udf's. I have to increase the velocity of particular domain with some value. Assume I am having four zones out of which I have to increase the velocity of first zone with some value. Is it possible through udf's Regards Karthick |
April 7, 2004, 19:48 |
Re: Accessing a zone
thread *tf; int id=3 ; tf=Lookup_Thread(d,id) where d is the domain pointer and Id is got fom the BC panel for different zone. once you get the pointer you could set the values. or in the define_profile you could check for where you are and set the values only when you are in the right zone . c_centroid could be used to get ur position. -Ajay
April 8, 2004, 05:57 |
Thanx ajay
It worked well Regards Karthick |
April 9, 2004, 13:51 |
Hello ajay
I am having one more problem. If I try to patch the velocity with some values, turbulent viscosity is limited to 14285 cells error I am getting. Is it due to our udf...How can I get rid of it? Regards Karthick |
April 16, 2004, 01:08 |
Hi Karthick,
If that is only warning message, you can pay no attention to it. Yo can set the limitation to the value you like. regards, Benny |
Display Modes | |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 18:51 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 02:08 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 09:42 |
accessing a zone | yobee | FLUENT | 2 | July 5, 2004 11:54 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 16:52 |
