April 8, 2004, 20:41 |
Equivalent area in 2D axi-symmetric model
I am working on a steam turbine rotor-stator interaction problem. As part of the solution, i am solving with 2D axisymmetric model first and proceeding to the 3D sector model for further analysis. I know the 3D area of the inlet and i want to model the 2D equivalent length. Can I use the formula, 3D area = pi*(R2Sq. - R1sq.) to get the R2 value. Thanks in advance |
April 9, 2004, 15:45 |
Re: Equivalent area in 2D axi-symmetric model
if you know the radius then use it as the equivalent length in 2D. i hope this helps David |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
doubts about axi symmetric moving reference frame and | eers | Main CFD Forum | 0 | July 9, 2009 15:53 |
simulation results for k-w model and SST model | Li | CFX | 7 | June 29, 2007 04:19 |
multiphase interfacial area density model | Paul | Main CFD Forum | 0 | August 5, 2003 17:33 |
