Home > Forums > FLUENT
gambit help!
Old   April 11, 2004, 04:15
Default gambit help!
danel
i have used gambit for 2d problem,x is 0.2m,y is 0.1m. i set x 20 points,y 10 points,but fluet check it face is 0.01m2,why?it should 0.0001m2. thanks in advance.
Old   April 11, 2004, 13:20
Default Re: gambit help!
solomon
It sounds it has to do with units. The default unit in FLUENT is SI. Keep as is for x, 0.2, and for y, 0.1 in GAMBIT when you create your geometry instead of 20 and 10.
Old   April 14, 2004, 22:33
danel
Thank you sir!
Thread Tools
Trackbacks are On
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 09:33
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 04:10
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 23:26
