Length Scale vs. Hydraulic Diameter?
Old   April 12, 2004, 09:52
Default Length Scale vs. Hydraulic Diameter?
Will
I am running a case where I have mass flow inlets. I have 10 large holes and 18 small holes. The ratio between the large hole and small hole is 1.5:1. My domain has periodic boundaries on each end with an outlet opposite and upwards of the holes. My question is should I use the length scale of the domain or hydraulic diameter of each hole? What I mean for length scale is the distance between the periodic boundaries. Currently I have each hole as a mass flow rate inlet, however I created the mesh where all the holes are one mass flow rate, where in Fluent I separated the holes. Which one would create the most accurate result? Since I do not have experimental results I do not know. I currently ran the model and got results for the holes as one entire mass flow rate. The results show that the velocity is the same for all holes. With this case I used the length scale. I know the velocity cannot be true since mass flow is related to the area. Now, I am using each mass flow rate inlet as an indivisual inlet and am getting results where the smaller holes now have the larger velocity. Can anyone give me help?
Old   April 13, 2004, 06:09
Default Re: Length Scale vs. Hydraulic Diameter?
Dmitry
Hi, I think it's a good idea to create 2 boundary inlets. First for small holes, and second for large holes. In this case you can set hydraulic diameters for both (large and small) holes. Also, i think it's more correct to use hole's diameters as length scale in your problem.
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
hydraulic diameter in 2d ahsan FLUENT 2 August 28, 2009 15:22
Importance of Hydraulic Diameter Value for Compressible Flow RyGuy FLUENT 0 August 6, 2009 10:58
Hydraulic Diameter or Length Scale Bob FLUENT 3 June 17, 2004 09:13
