April 10, 2004, 09:10 |
modeling a intake
hi
i am a user of fluent 6 and gambit 2. i want to model a intake that have no cone and work with a single normal shock. i want capture normal shock in enterance of intake. please help me thabks bye |
April 15, 2004, 02:41 |
Re: modeling a intake
try a simple axisymmetric geometry at first. use an inviscid approach to solve the problem, with the coupled solver. set the Mach number and pressure and temp at the inlet, the outlet must be pressure based. if the outflow condition is completely supersonic then the pressure value speified will be ignored and the variables will ne extrapolated from the interior of the domain.
cheers nandu |
Modeling intake and exhaust in ICE | Alexvader | OpenFOAM | 2 | September 26, 2011 13:50 |
Modeling of intake structure | prem | FLUENT | 0 | February 5, 2006 06:38 |
Modeling of a airflow in a intake manifold | Jack | FLUENT | 1 | September 21, 2003 22:22 |
Modeling of a airflow in a intake manifold | Jack | Siemens | 1 | September 15, 2003 05:12 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
