Udf problem
Old   April 14, 2004, 10:46
Default Udf problem
Karthick
Hello all
I am writing a simple udf to get the temperature at each cell during iterations. It is interpreting well. But when I try to run the iterations, it is showing Access_violation error and it comes out.
What may be the problem? Also I am having one more doubt. Whether can I include the udf in between the runs? It is leading to always error. Whether is it permissible in Fluent.
My udf is given below: #include "udf.h" DEFINE_EXECUTE_AT_END(my_execute) { Domain *d;
int ID=2;
Thread *t=Lookup_Thread(d,ID);
cell_t c;
FILE *fp4;
int i;
real temp=0.;
fp4=fopen("temp_zone2.dat","w");
begin_c_loop(c,t)
temp=C_T(c,t);
fprintf(fp4,"%g\n",temp);
i++;
end_c_loop(c,t) printf("The %d values ", i); fclose(fp4); }
Old   April 14, 2004, 18:33
Default Re: Udf problem
Ajay
Karthik ,
you are missing
d=getdomain(1), use it before
Should work then
-Ajay
Old   April 15, 2004, 01:51
Karthick
Since Get_Domain(1) and Thread *t=Lookup_Thread(d,ID) both are same, we can use either of two.
Is it right?
Regards Karthick
Old   April 15, 2004, 10:05
Ajay
No they are not the same .
will return a thread pointing to the ID number which you specify .Each boundary or zone is associated with an unique ID. but the other paramter you need which is d the domain pointer is not passed automatically when you use define_execute_at_end you need to get the domain ponter by using d=get_domain(1)
-Ajay
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
