Air foil, drag coefficient
Old   April 14, 2004, 17:33
Default Air foil, drag coefficient
Amit
I am trying to model an airfoil using k-epsilion model (standard wall treatment). Inlet air velocity is 100 m/s with 12 degree angle of attack. I get unusually large values for drag and lift coefficients (approx. 6000). What am I doing wrong?
Old   April 15, 2004, 00:21
Default Re: Air foil, drag coefficient
Dmitry
Hi, as you know Cx = X/D, where D = 1/2*rho*U^2*A, rho - density, U - velocity, A - area, X - force. FLUENT uses values which are specified in FLUENT reference panel (in FLUENT menu: report->reference values) by default. I think you must set correct values for density, velocity and area there.
regards
Old   April 16, 2004, 00:40
Amit
Thanks Dmitry.... that did the trick !!
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 09:22
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
