about 3ddp &3d
Old   April 18, 2004, 13:15
Default about 3ddp &3d
zwdi
Hi everyone,
I met reverse flow in my 3DDP calculation when I used velocity and turbulent parameter(k,epsilon)UDF as inlet boundary conditions. I want to initializ calculation from velocity inlet. When I choose calculate from velocity inlet,even though my velocity inlet has value larger than 0, Fluent only use 0 as initial velocity value. But when I change calculation from 3ddp to 3d, Fluent can use my current velocity profile value as the initial value. Also reverse flow disappeared in my calculation. For my case, I think results got from 3ddp is much better than those got from 3d. So could somebody know why I could not initialize calculation from my current velocity value(not 0) when I use 3ddp? Add one point, for constant velocity inlet value and constant turbulent parameters, there is no this problem. Only by using UDF turbulent parameter and velocity inlet and 3ddp, this problem happened.
Thanks a lot.
Best regards, Zwdi
Old   April 18, 2004, 14:19
Default Re: about 3ddp &3d
co2
what do you mean by UDF turbulent parameter ?
Old   April 18, 2004, 14:36
zwdi
Thanks for your response.
I have the experimental data of turbulent intensity and turbulent length sacle for inlet boundary conditions. Then I can calculate turbulent kinetic energy and turbulent dissipation rate for inlet boundary conditions. By using UDF I can input these data into Fluent boundary conditions panel. Same situation is for velocity inlet boundary conditions. The problem is that Fluent could not set the initial velocity value as my current velocity value even though I initialized from velocity inlet. Fluent always set initial velocity value as 0m/s. In this case, reverse flow appeared in my calculation, which affects my results convergence. This problem disappeared when i use constant turbulent parameter(such as intensity 10%, length scale 1m). And if I changed from 3ddp to 3d, this problem also disappeared. I don't know what causes this problem. Thanks again for your time.
Best regards, Zwdi
parallel mode failure in 3ddp but not in 2ddp ak6g08 FLUENT 1 September 22, 2009 06:56
parallel mode failure in 3ddp but not in 2ddp ak6g08 Fluent UDF and Scheme Programming 0 September 22, 2009 06:16
Parallel processing with 3ddp Error Kartik FLUENT 0 February 20, 2009 14:57
when use 3ddp? Txema FLUENT 3 February 21, 2007 16:11
2d,2ddp,3d,or 3ddp sean FLUENT 2 March 26, 2001 07:19
