Home > Forums > FLUENT
Urgent! how to get area through UDF?
Old   April 19, 2004, 03:38
Default Urgent! how to get area through UDF?
David
The following sentences of UDF are used to get the coordinates and pressure of the centriods on the specified boundary. And also I want to get the area of the face cells on the boundary to calculate the force. Which macro should I employ in this case and how?Thanks.
begin_f_loop(f,t)
F_CENTROID(x,f,t);
fprintf(fload3,"%10.5lf %10.5lf %10.5lf %10.5lf\n",x[0],x[1],x[2],F_P(f,t));
end_f_loop(f,t)
Old   April 19, 2004, 05:54
Default Re: Urgent! how to get area through UDF?
FJ
F_AREA(av, f, t) must be defined and NV_MAG(av) is summed .
--here--
av[ND_ND};
real area;
begin_f_loop(f,t)
{ F_AREA(av, f, t)
F_CENTROID(x,f,t);
area += NV_MAG(av);
end_f_loop(f,t)
Thank you
FJ
Old   April 19, 2004, 09:07
David
Thank you very much.It have a litle question.It seems that the array av[ND_ND] should be declared a type"real av[ND_ND]" otherwise Fluent will report some errors occur.
Old   April 20, 2004, 00:50
FJ
Oh,sorry! ."real av[ND_ND]"!.
FJ
Thread Tools
Trackbacks are On
Area of a particular face of the cell using UDF krish Fluent UDF and Scheme Programming 20 September 16, 2015 05:08
Face/Surface area export (urgent) DS FLUENT 7 June 24, 2014 10:49
Please help to urgent for UDF P9408 Fluent UDF and Scheme Programming 3 August 31, 2011 00:51
Magnus lift force using UDF - urgent help please Angela Wang FLUENT 2 December 17, 2008 07:03
URGENT custom property for UDF Sandilya Garimella FLUENT 0 May 19, 2008 12:35
