i begin use udf please help
i start use UDF .Now i have cas file and udf file. i can not run udf .i need to know which directory i must save udf file??? please tell easy thank a lot
Re: i begin use udf please help
Hi tana,
You shuold make sure that your UDF source file are in the same directory containing your case and data files. Regards, Allen |
Make sure ur udf files are in same directory.. and also interprete the file using DEFINE>FUNTION>IN.... OR COMPILE
then u could have it ready whr need... just click on pull down arrow and select the ur udf. Alamgir |
