ACCESS VIOLATION during autosaving case file
Old   April 20, 2004, 05:14
Default ACCESS VIOLATION during autosaving case file
Ryan
I am now using VOF model with dynamic mesh. At first I test it with coarse mesh, it works well. Then I fine the mesh and set autosave every 100 time steps. However, every time Fluent autosave case file, ACCESS VIOLATION error always happens, and the case file can not be totally saved. Despite of this, the computation can continue if I give up autosaving the case file.
What is the reason for this and how to solve, Anyone knows? thanks.
Old   April 20, 2004, 10:32
Default Re: ACCESS VIOLATION during autosaving case file
Ryan
In addition, I use a udf to define the motion, and the mesh motion is what I expected. The problem is that mesh information of each time step can not be write into case file completely (whether or not autosave is used). Error stated above occurs when only a part of case information is written.
To my great surprise, even this error occurs, after I cancel the operation of writing into case file, the computation can continue without any problem. I can autosave data file, but not case file. However, how can I process the data file later without its case file.
I am really confused why the mesh can not be written into case file. Who could help me out?
Access violation error pointer to a file salihovic FLUENT 0 February 8, 2011 10:18
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 16:31
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
