Surface points
Old   July 21, 2010, 13:17
Default Surface points
Yarzar
ATOTA is on a distinguished road
I can't create any surface points in my domain. I tried everywhere and it won't work. What should I do ??
Plz help.
Thanks !!
ATOTA is offline   Reply With Quote
Old   July 21, 2010, 14:17
Chris
Chris D is on a distinguished road
I thought you got it all taken care of here. What specifically is the problem?
Chris D is offline   Reply With Quote
Old   July 21, 2010, 14:22
Yarzar
That was the problem of inputting them with less time.
Now, I could input them easily but fluent won't accept the points.
It says "surface creation failed ocject #F"
For one case, only a few poitns were refused but for another one, fluent won't accept any of the points. The coordinates are right because they worked fine in Workbench.
Any suggestions ??
Old   July 21, 2010, 15:04
Chris
It seems like this error occurs when you attempt to create a point that is outside of the solution domain. Have you made sure that the units of coordinates of the point match those of the solution?
Old   July 23, 2010, 15:48
Yarzar
Thanks !
it seems like I had several problems. First, my units were in mm and FLuent was set in m. Another thing was that I had to shift the points about 0.1mm from the actual place to not interfere with the boundary...
Thnaks again :-)
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
