about userroutine in fidap
Old   April 5, 2004, 23:31
Default about userroutine in fidap
zht77
hello!
i encourt a difficult about userroutine using fidap.i don't know how to use it.i do it following help of fidap,but it dosen't work.could u help me?
Old   April 21, 2004, 10:56
Default Re: about userroutine in fidap
mario
Hi. Fidap use two types of subroutines:
FIDAP SUBROUTINES and FISOLV SOBROUTINES the first is not function of time, the another yes.
Files for build the subroutines are in paht:
Fluent.inc\fidapxxx\scr (depend of your system)
Their names are:
fisolv_user.f
fidap_user.f
You should edit this files and fill the soubrutine that you need. (you can do a copy whit another name for secutity and fill its)
Then, you should compile the subroutine, for this you need execute the program "user_sub.bat" in the line of command, for example:
(for PC) user_sub fidap exefile fidap_user_modif
and
user_sub fisolv exefile fisolv_user_modif
or
(for UNIX) make_fidap fidap_user.f
and
make_fisolv fisolv_user.f
you will obtain a file:
exefile.exe (for PC)
fisolv_user.exe (for UNIX)
this file you can use when you will run the fisolv, in the RUN command yuo need fill the item "FIDAP EXECUTABLE" or "FISOLV EXECUTABLE", depend your necessity.
Moreover, you can run from bath mode, on this form:
fidap -id xxx -fidapexec exefile.exe
and
fidap -id xxx -run fisolv -fisolvexec exefile.exe
Well, I hope that help you. Sorry for my English.
Mario
Fidap to Fluent Ravi FLUENT 3 July 10, 2008 13:31
user_sub FIDAP doesnt work semetay FLUENT 3 July 22, 2006 19:51
A doubt about Fidap Luca FLUENT 0 January 5, 2006 04:48
how to apply mixed BC by using Fidap subroutine? Ning Yang FLUENT 0 November 23, 2004 19:50
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 15:56
