3D species transport model - 1
Old   April 21, 2004, 15:44
Default 3D species transport model - 1
co2
A cylindrical tank contains grain at the bottom. Grain is modeled as porous zone Tank walls are thin but are modeled as solid zone for sun radiation calculations (Heat source terms are specified in the tank walls to account for sun radiation) Grain liberates co2 gas due to grain respiration Heat is also liberated during grain respiration and has been incorporated in the engery source term in porous zone pannel I am using mixture template consisting of co2 + O2 + N2 There are no reactions involved I am using species model
question: When I run my 3D unsteady model with air as fluid I get good convergence, but the moment I switch to mixture template, my continuity residual does not go below 0.001 ----- Does anyone know why this is happening? I am sure that I have a very good mesh with 120000 cells (all hex) --- I am surprised and disappointed that I am facing this roadblock in solution to my problem -- PLEASE HELP ..
Old   April 23, 2004, 05:20
Default Re: 3D species transport model - 1
emre
I had a similar problem 3D, spe4, all hex mesh and heat xfer. I started with no species as you did. Also I ran the cold flow solution. Later on I activated species transport equations and then energy equation, (for incomp. ideal gas). Also the under-relaxtion factors were all 0.1-0.2 less than the defaults. BTW, my model did not have any porous media which may make the convergence harder.
Hope this helps Regards
questions about species transport through walls shuqin FLUENT 13 April 9, 2014 03:42
Divergence problem for species transport model MY FLUENT 3 January 11, 2014 05:46
species transport model or mixture model? achaokaoyan Main CFD Forum 0 July 10, 2010 11:52
species transport in water lyn FLUENT 1 December 12, 2007 19:15
Can Fluent handle species transport in multi-phase Roger FLUENT 1 January 30, 2003 20:12
