April 25, 2004, 10:21 |
One Dimentional Flow (Heeeeelp)
Hello everybody
I think I have a simple problem. I am going to solve the flow equations (time dependent) for natural gas in a very long pipeline. As the diameter of the pipe section is really negligible with respect to its length,I just need Fluent to solve one dimentional flow Eqs for me. What I want to know as a result is the change in basic flow parameters( velocity, temperature, pressure) in different times in distances about 20-30 m . please tell me what fluent can do about one-dim flows. As far as I know the simplest grids Gambit can produce is two dimentional grid. thx |
April 25, 2004, 11:43 |
Re: One Dimentional Flow (Heeeeelp)
why dont you just solve an axisymetric problem? it wont be too expensive.
If not analytical solutions are available for this case. |
April 26, 2004, 00:03 |
Why do you want to do 1-D in fluent. It is simple to write your own code for it. However you you will never get a change in a spatial change in the velocity even in the developing region with 1-D solver. some temporal if you initialize with zero. A good test is to use just one grid and to simulate a channel with only one grid in the vertical height. Boundary copnditions you use may be a slip wall.
Display Modes | |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 09:33 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 13:14 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 08:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 06:57 |
