April 29, 2004, 13:43 |
Floating point error
when i solve the problem ,the solver cann't run ahead,I found this words following:
Error: Floating point error: invalid number Error Object: () how can i do. my model: one pipe with length of 20m and diameter of 13mm. I try the scale and units after importing the mesh file from gambit. it's funny when i solve the problem,probly,i try tens of times ,just one time succeed ,I cann't get ideal of it .when i change the diameter into 15mm,I never suceed.Pls help me and give me some advice on model and solving processure . |
April 30, 2004, 02:22 |
Re: Gambit 2 Boundary Layers
(Cf. mail of An Modh Coinniolach Fri, 18 Jan 2002, 7:59 a.m.)
hello, I have the same error message (boundary layer heigth to lower) using Gambit 2.1.2; and I think it dosen't depend on the gambit release : in fact, I've noticed that it was because of the way the boundary layer expands over the face : the direction is almost perpendicular to the edge of the face where the boundary layer is defined (egde1 ]). So if the face has no perpendicular edges (egde1 | and edge2 / ), they can cross the border of the boundary layer (-), and the only solution is to lower the height of the boudary layer. ]------- /---| ]----- /-----| ]--- /-------| ]- / ]/ |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 05:11 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
