April 24, 2004, 22:51 |
about modeling the phase change!!
hi ,i'm modeling the flow in pipe with phase changes between liquid and gas.can fluent do it
April 27, 2004, 12:07 |
Re: about modeling the phase change!!
Based on the following part of Fluent documentations I think yes.
help/html/ug/node517.htm 12.1 Overview of Species and Reaction Modeling FLUENT can model species transport with or without chemical reactions. For information about modeling species transport without chemical reactions, see Section 13.4. Chemical reactions that can be modeled in FLUENT include the following: Gas phase reactions that may involve NOx and other pollutant formation, etc. Surface reactions (e.g., chemical vapor deposition) in which the reaction occurs at a solid (wall) boundary. Particle surface reactions (e.g., coal char combustion) in which the reaction occurs at the surface of a discrete-phase particle. Additional information on modeling of droplet/particle reactions is presented in Section 21.3. |
April 29, 2004, 13:42 |
can we do phase change for sand casting problems
simulation of phase change material melting | rosol | FLUENT | 4 | December 8, 2015 07:56 |
About phase change heat and mass transfer | Michael | FLUENT | 2 | February 13, 2011 01:49 |
Solid/liquid phase change using large viscosity | gregor.vidmar153 | OpenFOAM Running, Solving & CFD | 3 | June 10, 2010 06:31 |
water 2 phase, Change from hight to low temp | panuwat | FLUENT | 0 | June 19, 2006 08:50 |
phase change | rookie | FLUENT | 3 | June 12, 2003 20:47 |
