Home > Forums > FLUENT
RTD by CFD
Old   May 1, 2004, 12:10
Default RTD by CFD
Mohit
Hello all,
I am a Chemical engg student at IIT delhi and am working on determining the residence time distribution of laminar flow in helical tubes.
I have tried using the DPM model. Injecting inert particles at the inlet and monitoring their flow at the outlet using discreet phase sampling. But the process takes lot of time and is not accurate.
I want to know how can I use the species model to give a pulse input of a tracer at the inlet and how can I monitor its flow at the outlet.
Regards mohit
Old   May 10, 2004, 09:43
Default Re: RTD by CFD
zachi
Yes it will take a longe time depending on the length of your geometry. I think the species methode will last much longer! Are you sure your flow is laminar and there is no backmixing! Which density are your inert particles of!?...
regards
zachi
Old   May 10, 2004, 09:52
Mohit
The inert particles are of the same density as the fluid (1100 kg/m3). yes the flow is laminar. please let me know how to do it using the species model.
regards mohit
Old   May 10, 2004, 10:08
zachi
enable multiphase species, define species, define inlet of the species, unsteady calculations. Iwould say it is much more work to calculate RTD with the species model than working with DPM!
What is your geometry length and which model do you use for your calculations. Wher is your injection point or surface?
regards,
zachi
Old   May 10, 2004, 10:46
CFD Newbie
Hi zachi,
Can you tell me if it is possible to get RTD in a steady state simulation? And if so how can this be done?
Thanks
Tom
Old   May 10, 2004, 10:55
zachi
Using the DPM (discrete phase model) in fluent enables you to calculate a RTD in a steady state solution!
Compute your flow pattern Enable DPM Create your particel injection define your particles create a control-face report--> discrete phase--> sample!! Fluent will create a *.dpm file in which the passing time of particles at the control-face is recorded!
regards
zachi!
Old   May 10, 2004, 17:30
mohit
hi zachi,
my geometry length is 0.2 m with mean velocity of 0.15 m/s . my model is laminar& segregated. i inject at the velocity inlet using sueface injetions but i dont know how to inject a species as we inject particles
please reply soon regards mohit
Old   May 11, 2004, 03:03
zachi
You will have to create separate a fluid zone in which the species is injected and you must use unsteady calculations you will be able to create a monitor recording the flux at a defined control face or the outflow face! By using the outflow face you have to observe that you do not have any recirculations in your flow pattern!! I would do RTD calculations with DPM!!
regards
zachi!
Old   May 12, 2004, 19:35
ryan
I prefer to use the pathlines function (under Display) for this purpose, since the pathlines are assumed to be massless. You can adjust the number of pathlines released from a surface using a surface rake. Otherwise you're limited to the number of cells at the release surface.
Thread Tools
Trackbacks are On
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
Since Last June John C. Chien Main CFD Forum 3 July 12, 1999 09:38
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
CFD Symposium (Call for Papers) Chris R. Kleijn Main CFD Forum 0 October 5, 1998 10:25
