May 13, 2004, 22:48 |
UFD problem in DPM.
hi,all
my model is to calculate a gas-liquid flow in a water tank, different forces should be imposed on the bubbles, when the bubbles were under a horizontal wall, press and buoyant force are to be added; and if not, only buoyant force are to be added. would you please tell me how to use UDF to add different forces on the same bubble at different section of the water system in a model(i.e. the forces on bubbles are different when they changes the positions) ? thanks! |
DPM Parcel Number Problem | Shane | FLUENT | 7 | October 25, 2012 08:24 |
Problem in DPM | Harpreet | FLUENT | 0 | July 31, 2011 09:56 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
Parallel DPM Udf problem | dust_2 | Fluent UDF and Scheme Programming | 4 | June 11, 2011 10:03 |
DPM problem | Jane | FLUENT | 4 | February 20, 2004 03:24 |
