May 6, 2004, 09:35 |
heat generation rate w/m3 in 2D
Please help me understand the specification of heat generation rate. In electrical circuit boards the heating power is exactly known for example 1mW. Heat generation rate can be specified as a property of solid zone. I know the size of electrical heat-emitter-body so I can calculate w/m3. But how could I know if it is correct or not because the solver is 2 dimensional? I think Fluent use this heat generation rate to calculate heat without knowing the 3rd dimension of the heater body. Is it a bug in Fluent (should use w/m2 instead of w/m3 during 2D simulation) or I don't understand something? Thank you for your answer! |
May 6, 2004, 11:58 |
Re: heat generation rate w/m3 in 2D
Dear Laszlo:
I will tell you what I know. I also use w/m3 values for my 2d Axisymmetric flow calc. As far as I know, for 2D axi calc, fluent calculates the total volume by rotating your area around the axis by 360 degrees. In 2D calc, I think thickness of 1 m is assumed -- so do your calcs accordingly. Some one please correct me if i am wrong -- Quite possible. Thanks, CO2 |
Troubles with heat release rate | Xavier Ponticq | CFX | 4 | September 12, 2012 18:49 |
UDF for heat generation | prince_pahariaa | FLUENT | 4 | July 11, 2011 02:58 |
Diesel combustion simulation ( Heat release rate) | venkatesh | Siemens | 2 | April 29, 2009 07:38 |
Inconsistent Total Heat Transfer Rate | Ken Adams | FLUENT | 0 | July 24, 2007 11:04 |
Heating of a solid cylinder with internal heat generation | Sriram Popuri | Main CFD Forum | 6 | July 13, 1999 18:09 |
