minimum line length
Hi, guys I have a simple question about the limit of line length in Gambit. Actually, I tried to connect two vertexes which are 10um apart each other but I couldn't. Do you guys have any idea?
Thanks, Jay |
Re: minimum line length
Everything depends on the scale you are using in the Gambit session. Why don't you work in units of um instead of e.g. meters? Gambit does not need, it even doesn't care for your length units and you can change the scale in Fluent afterwards to get the proper physical scale for your problem.
Good luck, George |
thank you very much Jay
FYI, the minimum line length in Gambit is 0.0001, in my experience
