-   FLUENT (
-   -   Gambit problem.. (
jay May 17, 2004 21:01
Gambit problem..
Hey everyone..
I have a question about Gambit. I've met an undefined error in gambit and it automatically terminated. After that, I can not start gambit again. It automatically generates error message like
"/ File opened for write Mon May 17 20:50:27 2004. ERROR: IDENTIFIER "default_id" CURRENTLY OPEN"
Do you guys have any idea about this problem?
Should I re-install gambit?
Thanks in advance
soody May 18, 2004 01:20
Re: Gambit problem..
you can start Gambit with this method: click (START) then (RUN)and write:
d:\\ntbin\ntx86\gambit.exe name
this is the path that gambit is installed.every time that you run the program ,use different words instead of (name). some thing else;you must completely exit the program at the end.
George May 18, 2004 03:37
Jay, look in your working directory for a tiny file with .lok extension. When gambit terminates ubnormally, it leaves this file and a temporary working directory behind. Just delete them and you'll be able to run it again. (The file is just a marker of an open session.)
jay May 18, 2004 10:38
Thanks a lot, George It works. Perfect !!!
mohitmech October 8, 2011 04:15
Gambit Problem
I want to mesh a 3D tube in Gambit, but in a volume mesh it writes this ERROR:'' Edge edge.2 and edge.4 are taken as the defult periodic edges for intervals control for face face.2 ''.
Cuold you help me?:confused:
-mAx- October 10, 2011 01:10
did you mesh something prior to the volume?
post a picture
