Home > Forums > FLUENT
Wall Shear Strees
Old   May 19, 2004, 13:55
Default Wall Shear Strees
Melih
I need to get wall shear strees values by writing UDF. I found out a discussion about this topic in this forum between Mike and Markus, but it did not help me. So, is there any macro to find wall shear stress?
I was also thinking about getting this values in an different way. Fluent can give the values as a postprocess.So, can I save the values in a file and then read in my UDF? I think, the DEFINE_RW_FILE (Section 4.2.5) macro can do this, but i don't know how to do? Could you please give some detailed advices?
Best Regards...
Melih
Old   May 20, 2004, 02:38
Default Re: Wall Shear Strees
Chetan Kadakia
Doesn't Fluent allow for the solution of wall shear stresses already? I don't think you need a UDF.
Old   May 21, 2004, 18:37
Ajay
include storage.h header file
define real wallshear[ND_ND];
face = face variable ;
tf= face thread
NV_V (wallshear, =, C_STORAGE_R_NV(face,tf,SV_WALL_SHEAR));
this will give you the wall_shear_force multiplying by the area vector would give you the wall_shear_stress.
Hope this helps ,
Ajay
Old   May 22, 2004, 07:03
Melih
Thanks Ajay, I'll work on it...
Old   May 25, 2004, 06:57
Melih
Hi Ajax,
I used the macro given by you. The macro seems to give the wall_shear_force as you said.I got these forces as wallshear[0],wallshear[1] and wallshear[2]. In order to get the stress, I divided these components by the magnitude of face area normal which is simply the area of each face. After doing this, I assumed that I got the stresses in x,y and z direction. But the problem is that, although the order of magnitude are resonable by the wall shear stress found by FLUENT, they are not equal(sometimes I get negative and positive values, but FLUENT gives positive, and vice versa) . However,when I calculated the magnitude of wall shear, I saw that they were nearly equal with that of FLUENT. Any comments?
Thread Tools
Trackbacks are On
Measuring wall shear stress in bend pipe liguifan OpenFOAM 70 December 9, 2015 04:49
Wall Shear Stress mtl40 Main CFD Forum 3 January 23, 2010 03:08
Problems with wall shear stress. xiexiehezuo FLUENT 1 September 22, 2009 12:26
What does “Mean Wall Shear Stress” mean? dfytanid FLUENT 0 September 16, 2009 08:15
Macro to set Wall Shear Stress Satish FLUENT 4 November 26, 2003 15:46
