Mass flow rate
Old   December 18, 2017, 13:33
Default Mass flow rate
Hells Blade
hellsblade.91 is on a distinguished road
I am calculating the mass flow rate from 5 inlets when air flows to the bottom(outlet) however in fluent solution the graph of mass flow rate which we get i believe is mass flow rate flowing from each element is there a way to get a cumulative graph
From CFD Post I get a mass flow on outlet as
-0.0647398 kg/s
I am not sure if these value if completely justified with my simulation
hellsblade.91 is offline   Reply With Quote
Old   December 18, 2017, 13:38
Haidar Fakhri's Avatar
Suraji
Haidar Fakhri is on a distinguished road
Hello adas
I try to answer ur question
The back flows maybe influence the mass flow outlet. And absolutely u used transient solver. U should considering the the back flow from each inlet. The boundary layers can be influence too.
Thanks
Haidar Fakhri is offline   Reply With Quote
Old   December 18, 2017, 13:50
Hells Blade
Haidar thanks for your reply but how can the reverse flow at outlet be eliminated i am using pressure inlet and pressure outlet boundary condition and teh pressure is between 12-24 bars at inelt
Old   December 18, 2017, 13:54
Suraji
Trying to use velocity inlet and out mass flow. Reduce the roughness of wall
That u used pressure outlet u should input the pressure outlet.
Old   December 18, 2017, 13:59
Hells Blade
I am simulating my flow with pressure inlet for diff pressures 12-24 bar the pich attached is 24 bar in velocity inlet boundary condition do i enter my total inlet pressure in outlow gauge pressure i dont think there is a way to define my pressure in pressure in velocity inlet BC
boundary condition with pressure AND mass flow rate tsi07 FLUENT 3 April 14, 2022 12:32
Higher mass flow rate at outlets as compare to inlet Ahmed Saieed FLUENT 0 April 3, 2016 23:08
trying to perform accurate mass flow rate sampling through hot-film probe UTA_ARC ANSYS 0 December 2, 2015 13:20
Calculating mass flow rate at multiphase flows Kuslo187 OpenFOAM Post-Processing 1 August 21, 2015 18:11
mass flow rate in DPM steady tracking Roule FLUENT 4 June 1, 2015 10:44
