May 23, 2004, 02:07 |
boundary condition
I am trying to model a case of centrifugal pump. I have rate of flow and pressure intlet.What bounday types should I use? Can I have a velocity inlet(-) Or should I use a pressure inlet and outlet in this case? Any advise?
May 24, 2004, 00:37 |
Re: boundary condition
Hi Amir,
With regard to ur problem, I guess that u have some experimental results and ur comparing the same numerically, it always adviced that u model the problem as realistic to that of the Experiment,so that u can ease u comparison. krishna. |
May 24, 2004, 02:40 |
Hi krishna, thank for ur attention to me, I run this problem with b.c that said but the resaults of it is not correct. what is the mistake?
May 24, 2004, 03:30 |
hi Amir,
Then I think u must have a check on the Turbulence model(s),and try various models to set a bench mark for ur problem, if u use 1, also check the dimensions of the Grid while reading into Fluent. I think this should help. krishna. |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 05:05 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 12:26 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
