high mach number
Old   May 22, 2004, 11:50
Default high mach number
Arthur Gamara
Dear cfd guys and girls, i need to set my Fluent 5.3 for simulate high Mach number, so that i can see shockwave, can you people teach me how to set it??
Old   May 24, 2004, 00:40
Default Re: high mach number
krishna
Dear Arthur,
I think it will be easy if r able to convert the Mach Number in terms of Velocity in m/s so that you can specify the velocity itself, I am not so familiar with 5.3 version, this is one of the option.
krishna.
Old   May 24, 2004, 10:36
Arthur Gamara
Thank you Khrisna.
I already tried your suggestion, but thre is a problem, when it iterating, the result become divergent, it indicates there are shockwave. Is it true that Fluent can't simulate shockwave???
Old   May 24, 2004, 16:57
STK
HI! DO NOT SAY THAT AGAIN !!!!!!!! firstly to see shocks, study the flow around a simple curved object, or the flow in a converging nozzle. better do the first one. Far away from the foil apply FAR-FIELD BOUNDARY CONDITIONS with 101325 pressure, Mach=1.8 Set OPERATING CONDITIONS TO 0 from 101325 and run inviscid model. For the airfoil use no slip conditions (WALL).you will see the shocks. I am writing papers with Fluent on Hypersonic flow if you want anything contact good luck!
Old   May 24, 2004, 23:09
Arthur Gamara
SORRY.... STK! I really don't mean it. anyway what's your email, i'd like to contact you bout supersonic flow (mach number=2.3)
where i can find FAR-FIELD BOUNDARY CONDITIONS in Fluent???
Thank you very much!!!!!
Old   May 25, 2004, 04:38
STK
IT IS MY PLEASURE HELPING YOU! LOOk THERE IS A PROBLEM because YOU USE 5.3 AND I USE VERSION 6.1.18! I DON'T KNOW WHERE YOU CAN FIND FARFIELD. LOOK AT THE MANUAL. I BELIEVE THAT CERTAINLY BE SOMETHING THERE!My MAIL IS:aerodynamifun@hotmail.com. regards
Old   May 25, 2004, 08:37
Arthur Gamara
oh... the version huh..!! is there otherway to see it?
Exporting results and Mach number calculation pawan1989 CFX 0 July 14, 2010 13:05
Fully Expanded Jet Mach Number. oe_jet Main CFD Forum 0 June 28, 2010 11:40
Strong oscillation at transonic mach number martingariepy FLUENT 2 May 12, 2009 11:40
Mach number Singh Main CFD Forum 0 July 2, 2008 09:51
Difficulties in solving a high Reynolds number Flow? wowakai Main CFD Forum 10 December 29, 1998 13:46
