vof problem
Hello my friends;
I started the simulation of 2 phase flow in a 180 degree bend (open channel) with a lateral intake, using VOF method. but there is a concern: 1- after many hours past for iteraation, there are no changes in water surface and it remeins a flat surface. would you help me? best wishes, a.safarzadeh |
Re: vof problem
Hi Have u check once input velocity profile.Is it time dependent or constant.Unless it is time dependent u cant get some waves. Kethireddy---RWTH-aachen-Germany
Re: vof problem
Hi my friend
thank you for your attaention. the input velocity profile is constant. in this problem,at the t=0 sec, i patch an adapted region that hase a constant depth at all of the modell ( e.g 10 cm of water for 25 cm depth of channel) and i want to determine the steady state water surface profile that developed because of inlet velocity and gravity force. in this case, the surface must has a superelevation, but the results dont show this phenomenon and the first depth stays constant. A. Safarzadeh |
