May 25, 2004, 17:31 |
convergence problem
Hi all,
I'm simulating a 2-D flow past flat plate in order to investigate the boundary layer (laminar/turbulent). The continuity residual is converging to high value (1.5e-1) whereas the x and y velocity is converging to 1e-7. I'm pretty sure I have to change the under relaxation factors...anyone know what's the best choice to this kind of problem ? Thanks, John |
May 25, 2004, 18:40 |
One more question...
One more thing...what are the best sub-models of k-w and k-e to use for a wall bounded flow ?
I know k-w is much more suitable for this case but I still want to check k-e. Thanks john |
May 27, 2004, 06:08 |
Re: One more question...
In resononce to the first question about continuity residuals, depending on what you are simulating, changing an OUTFLOW B.C. for a PRESSURE OUTLET B.C. I would first try lowering pressure and then try lowering momentum.
May 27, 2004, 09:55 |
Hi, a second possibility would be if you are simulating turbulent flows to change your simulation to an unsteady one!! You have also to look at your wall treatment methode and your grid resolution!!
regards zachi |
May 27, 2004, 12:57 |
The single equation K-w model is best for boundary layer flow if there is no recirculation. However the K-w model does not allow for the transport of turbulence therefore if you are looking at the turbulent effect away from the wall then a K-e model should be used. If you are having problems with continuity try reducing the relaxation factor for momentum and pressure also check the grid on the boundary and your Y-plus values.
Display Modes | |
convergence problem when use pisoFoam, LES for wind tunnel case | Forrest_Lei | OpenFOAM | 3 | July 19, 2011 07:00 |
convergence problem | commonyue | Main CFD Forum | 1 | December 1, 2009 04:54 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
3D Fluid Flow Convergence problem | Emily | FLUENT | 2 | March 21, 2007 23:18 |
Non Convergence of 3D Heat transfer cfd problem | Balraj | Main CFD Forum | 3 | December 9, 2004 01:24 |
