-   -   import *.cas file to Gambit error (http://www.cfd-online.com/Forums/fluent/33828-import-cas-file-gambit-error.html)
zwdi May 27, 2004 17:24
Dear everyone,
I imported *.cas file to Gambit successfully before. Today I want to import the new *.cas file to Gambit(Unfortunately I deleted the old *.cas file which can be imported to Gambit successfully). But I failed. The error says : Error: bad syntax. Usage: dimension: [-d2 :-d3:-surface] read_format: [-tAnsys : -tCFX :....................: -tTECPLOT] zone: [-zGROUP : -zID : -zPRESSURE : -zTEMPERATURE : -zNONE] default is -zGROUP write_format: [-oFIDAP7 : -oRAMPANT]
Error: the fidap neutral file header (record 1) is non-standard. Error: Error encountered while reading the header information. Gambit is unable to import utility fe2ram -mle-006 -d3 -tRAMPANT -oFIDAP7
I didn't change anything. The only difference is that the fluent version changed from 6.1.18 to 6.1.22.
Could anybody give me any help? I would be very appreciated for it. Thanks.
Best,
Zwdi
zwdi May 27, 2004 17:28
Re: import *.cas file to Gambit error
Could anybody explain what that error means or what can cause that error? Thanks a lot
Best, Zwdi
zxaar May 28, 2004 13:19
how about changing the gambit version too with fluent version, that is can't u have the latest gambit from fluent web site
zwdi May 28, 2004 16:10
thanks for your response, zxaar.
Do you think the error is caused by software version updating?
Best,
Zwdi
zxaar May 29, 2004 03:57
actually i thought if fluent people have done some changes in fluent case format (may be a little), they might have fixed the problem in gambit too, so that it can be imported easily., its just a thought, but u can check it, by downloading the newest version of gambit from fluentusers.com
zwdi May 29, 2004 12:05
Thank you very much, zxaar.
Zwdi
zxaar May 29, 2004 14:07
if u try let us know whter it works, will be a help
zwdi May 31, 2004 14:34
hi Zxaar,
I had a final try. It works now. Thanks
Best,
Zwdi
zxaar June 1, 2004 03:48
i thought so.
