June 5, 2004, 02:10 |
initializing the solution
hi all,
i have a doubt when initializing the solution in Fluent.which zone is to be selected? would "all zones" be a good option? else clicking "init" without selecting any zone is right? sometimes when i select all zones Fluent receives a fatal error? what would be the cause? thanks for any suggestions? regards Thiyaga. |
June 5, 2004, 07:44 |
Re: initializing the solution
Haha, i have the same question as you in my mind
June 6, 2004, 02:48 |
Hi
your initalization should be some reasonable value. The code is supposed to accept any kind of initialization as it does iterations, but what happens in some case of bad initialization like having zero quantities, the code blows up. You can compute the initialization from the region which you think would give values close to the final solution over the whole domain. Like the flow inside a pipe is dependent on its velocity inlet, so the initialization is computed from the inlet. Good initial guesses also lead to faster solution. Hope this helps. Arun |
Integrated conjugate heat transfer solver in OpenFOAM | hjasak | OpenFOAM Running, Solving & CFD | 172 | April 13, 2023 00:42 |
Solution Initilization | Vijay | FLUENT | 0 | February 12, 2009 18:23 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Mesh independent solution | CFX Begineer | CFX | 0 | October 27, 2002 10:54 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 13:37 |
