Home > Forums > FLUENT
WRITING TO A MPEG FORMAT IS A PROBLEM???
Old   June 14, 2004, 16:19
Default WRITING TO A MPEG FORMAT IS A PROBLEM???
STK
WHEN I PLAYBACK A SEQUENCE FILE IN FLUENT IS OK.
WHEN I AM WRITING IT TO A MPEG FILE THE FILE DOESN'T PLAY IN THE USUAL WAY. I MEAN THAT IT PLAYS TOO FAST. HOW I CAN SOLVE THIS PROBLEM WITH OUT USING ANIMATION FRAMES AND EXTERNAL POST PROCESSING PROGRAMS (ONLY WINDOWS MEDIA PLAYER)??? THANKS
Old   June 15, 2004, 11:38
Default Re: WRITING TO A MPEG FORMAT IS A PROBLEM???
Arun
Hi STK,
You have an option while recording (a scroll bar which says (slow---fast). If that does not work, try Windows moviemaker. I know you can control frame speed there.
Arun
Old   June 15, 2004, 11:48
STK
Thanks Arun I'll try it Before I used windows media player, which it doesn't control frame speed.
Old   June 22, 2004, 07:05
ozgur
You can control the play speed in wmplayer version 9. I have another problem actually. The quality of the mpeg files is too bed. Is there a way to improve the resolution of the mpeg files created by FLUENT??
Thread Tools
Trackbacks are On
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 9 November 22, 2011 11:02
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 12:49
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
MPEG problem Gary Holland FLUENT 3 June 20, 2005 08:48
