-   -   Urgent Help Needed! (http://www.cfd-online.com/Forums/fluent/33963-urgent-help-needed.html)
Trias June 14, 2004 17:21
Urgent Help Needed!
If the fluid flows with a subsonic speed at the first contraction, then with a supersonic flow at the second contraction, what kind of solver setting is better for this kind of case?
Thanks a lot!
ROOZBEH June 15, 2004 08:18
Re: Urgent Help Needed!
Hi; Generally coupled solver is proposed to solve a compressible flows. I use this sover to simulate the flow in a converging-diverging nozzel. To capture shock with a good sharpness, use a second order upwind scheme to discretize convective terms.
ROOZBEH
Trias June 15, 2004 17:32
Thank you very much for your message! Normally, you use couple/implicit or couple/explicit? Thanks again!
ROOZBEH June 19, 2004 07:04
Hi; I use couple/explicit to turn on multigrid tecnique to increase rate of convergence.
Regards
