Home > Forums > FLUENT
3d volumes in GAMBIT
Old   June 17, 2004, 19:54
Default 3d volumes in GAMBIT
Sumant Mallavaram
Hi Folks, I am very new to GAMBIT and trying to mesh some bathymetry data. I am at a point where I have created faces by connecting all the points. I need to generate volumes and when I try to stitch faces I get an ACIS error 7500: faces are used twice, is this an open shell?
I am not sure what to do. Any guidance is greatly appreciated.
Thanks, Sumant
Old   June 18, 2004, 03:58
Default Re: 3d volumes in GAMBIT
ap
If you have complex volumes, you had better to generate them using GAMBIT elementary volumes instead of starting from points and faces.
This approach makes the mesh generation easier too, if you properly use the split and the connect functions.
However, GAMBIT can't generate a volume from faces if they don't define a closed volume.
Hi
ap
Old   June 18, 2004, 08:31
Bob
You may have have created two faces by stitching the edges twice. And then you meshed both of these faces. Then when you tried to mesh the volume Gambit gets confused and gives this error. You will have to find this duplicate face and delete it and then it should work. That is if this is the problem. Or you could have edges that need to be a face and you didn't stitch them. Also, you may have to heal the faces to eliminate geometric error, such as that the edges are not touching each other. By healing the faces and if this the problem by healing the faces a volume will be created. Hope this helps.
Thread Tools
Trackbacks are On
Problem with Volumes Gambit Danath ANSYS 1 October 19, 2011 08:20
Handling Virtual volumes in Gambit Bharath FLUENT 4 October 30, 2006 21:24
Ghosts Volumes on Gambit ?!! help please Andres D. Ortiz FLUENT 0 October 7, 2001 19:17
Gambit mesh & Negative Volumes Ashutosh FLUENT 5 February 21, 2001 01:59
volumes in gambit christof FLUENT 1 March 9, 2000 18:03
