June 14, 2004, 17:21 |
Urgent Help Needed!
If the fluid flows with a subsonic speed at the first contraction, then with a supersonic flow at the second contraction, what kind of solver setting is better for this kind of case?
Thanks a lot! |
June 15, 2004, 08:18 |
Re: Urgent Help Needed!
Hi; Generally coupled solver is proposed to solve a compressible flows. I use this sover to simulate the flow in a converging-diverging nozzel. To capture shock with a good sharpness, use a second order upwind scheme to discretize convective terms.
ROOZBEH |
June 15, 2004, 17:32 |
Thank you very much for your message! Normally, you use couple/implicit or couple/explicit? Thanks again!
June 19, 2004, 07:04 |
Hi; I use couple/explicit to turn on multigrid tecnique to increase rate of convergence.
Regards |
Display Modes | |
urgent help needed (rhie-chow interpolation problem) | Ardalan | Main CFD Forum | 2 | March 18, 2011 15:22 |
help needed in Turbulent flow (URGENT) | mike | FLUENT | 7 | November 7, 2008 06:11 |
Urgent help needed with spray injection | nick | Siemens | 14 | June 29, 2008 18:48 |
Urgent Help Needed! | Ken Adams | FLUENT | 3 | September 25, 2007 23:50 |
urgent help needed on dpm | vaishali | FLUENT | 3 | December 18, 2006 14:20 |
