Home > Forums > FLUENT
How to set Low-Re k-e model
Old   June 23, 2004, 18:57
Default How to set Low-Re k-e model
Frank
Hi
I use "define/model/viscous/turbulence-expert/low-re-ke" to add low-re k-e model into the GUI, but my FLUENT shows this function is forbidden. Is there any function can change this setting?
Thanks for the help.
Old   June 24, 2004, 01:40
Default Re: How to set Low-Re k-e model
sarah_ron
You'd better type it, sometimes copy and paste will result in the above information.
Old   June 24, 2004, 20:03
Frank
I read the case&data first. Then I can use the command to add low-re-ke into the GUI.
Thanks.
Thread Tools
Trackbacks are On
Low Reynolds Number SST Model Josh CFX 39 February 19, 2014 09:47
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Low Inlet Turb. Intensity - SST model not converge Pete CFX 0 November 12, 2005 02:26
Low Reynolds k-e model Frank Main CFD Forum 0 February 14, 2002 12:26
UPWIND-BIASED and Low Re K-Epsilon Model Valdemir G. Ferreira Main CFD Forum 5 June 19, 2000 23:13
