June 23, 2004, 18:57 |
How to set Low-Re k-e model
Hi
I use "define/model/viscous/turbulence-expert/low-re-ke" to add low-re k-e model into the GUI, but my FLUENT shows this function is forbidden. Is there any function can change this setting? Thanks for the help. |
June 24, 2004, 01:40 |
Re: How to set Low-Re k-e model
You'd better type it, sometimes copy and paste will result in the above information.
June 24, 2004, 20:03 |
I read the case&data first. Then I can use the command to add low-re-ke into the GUI.
Thanks. |
Low Reynolds Number SST Model | Josh | CFX | 41 | June 4, 2023 19:00 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Low Inlet Turb. Intensity - SST model not converge | Pete | CFX | 0 | November 12, 2005 01:26 |
Low Reynolds k-e model | Frank | Main CFD Forum | 0 | February 14, 2002 11:26 |
UPWIND-BIASED and Low Re K-Epsilon Model | Valdemir G. Ferreira | Main CFD Forum | 5 | June 19, 2000 23:13 |
