Solution limits
Old   June 6, 2004, 06:26
Default Solution limits
pp
Under Solve-Limits... there are variable solution limits. Default value for absolute pressure is 1 pascal but when my case is solved I have absolute pressure values in my domain less much more then 1 pascal (e.g. -80000 pascals). What I have to done to stop decresing absolute pressure in my domain.
Regards, pp
Old   June 28, 2004, 11:53
Default Re: Solution limits
mark
Are you sure that you're displaying absolute pressure and not the gauge pressure? Fluent works in guage pressure to reduce rounding errors. What operating pressure have you set? Fluent defaults to 103125Pa.
Absoulte Pressure = Gauge Pressure + Operating Pressure
Absolute Pressures below the limit set will automatically be set to the limiting value and a warning message will be displayed.
Redefining variables in fluent instead using limits (control solution) akhlaghi FLUENT 0 February 19, 2011 06:14
Steady solution from Transient simulations wawa FLUENT 2 November 9, 2010 17:44
Unsteady solution Christophe FLUENT 0 August 11, 2006 11:13
How to avoid exceeding solution limits for tempera xyx FLUENT 0 February 12, 2006 11:43
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
