about dynamic mesh model
Old   June 27, 2004, 09:21
Default about dynamic mesh model
lingo
Hi, everyone: My case is that: a wall is rotating whose rotational speed is varying with the time.So a udf and dynamic mesh model are needed.When I set the step size=T/100(T refers to the period)and iterate,messages appear as follows: " Updating mesh at time level N...negative volume: repeat smoothing negative volume: repeat smoothing negative volume: repeat smoothing WARNING: non-positive volumes exist. Error: Update-Dynamic-Mesh failed. Negative cell volume detected. Error Object: ()"
So, I reset the step size=T/1000. I works well .However, after sveral hundreds steps , the similar messages appears: " Updating solution at time level N... done. Updating mesh at time level N... WARNING: non-positive volumes exist. Error: Update-Dynamic-Mesh failed. Negative cell volume detected Error Object: ()"
I need several periods (several thousands steps)to investigate the unsteady simulation.
Could you give me any suggestions?
Regards
lingo
Old   June 30, 2004, 04:33
Default Re: about dynamic mesh model
emma
I think that the problem maybe lies in the too small volume mesh or the twisted mesh. Go back and chech your mesh, perhaps your mesh is too fine for your computer or your mesh type doesn't matches well with your problem. Hope it helps a bit.
Regards
Emma
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Some questions about mesh updating in dynamic mesh technique lzgwhy Main CFD Forum 0 June 14, 2009 08:01
Dynamic mesh - structured mesh mrestrepo30 FLUENT 0 June 3, 2009 15:40
problem about dynamic mesh of VOF model whpsoft FLUENT 0 September 8, 2005 23:06
How to define dynamic mesh model B.C using Profile David FLUENT 3 February 18, 2004 16:57
