about preview mesh motion
Old   July 8, 2004, 11:35
Default about preview mesh motion
lingo
Hi,everyone:
I failed to preview mesh motion when I used the dynamic mesh model for my 3D case.I set the step size=T/10000=0.0001s .But after one step,Preview-Dynamic-Mesh failed because negative cell volume detected.So I reset the stepsize=0.00001s,after 10 steps,it quit too.
I am sure that my udf is ok because it works well in 2d case.
Could you give me any suggestions especially about the mesh?
Regards
lingo
Old   July 8, 2004, 12:13
Default Re: about preview mesh motion
devan
First of all I hope the mesh is fine enough. 1.Check with size function variationand size function rate in remeshing. 2.Also try varying No. of iteration in Smoothing. I hope this will help u
Regards DEVAN
Negative Volume during Mesh Motion Analysis giov_ingr FLUENT 2 December 13, 2013 06:09
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Help with Mesh motion preview Mustafa Ayad FLUENT 2 January 20, 2009 22:40
Mesh motion Hex cells vs tets kev4573 OpenFOAM Running, Solving & CFD 6 December 13, 2007 14:37
