Home > Forums > FLUENT
transient analysis problem
Old   July 7, 2004, 05:29
Default transient analysis problem
NABEEL MOHSIN
hi, i want to ask how i determine that i should use couple solver or segregate solver for simulation of cooling of heated cylinder dipped in oil. can is it possible that first i start thermal analysis and then transient nabeel
Old   July 7, 2004, 17:54
Default Re: transient analysis problem
Ajay
you would want to use a coupled solver if you want to consider the effects of varying material properties with temperature.
yes you can forst do a steady state calculation and then go to a transient analysis
Old   July 8, 2004, 00:46
NABEEL MOHSIN
hi, thank you for answer it is free convection problem and should i use pressure inlet and outlet at outer walls of cylinder in which oil is present. nabeel
Thread Tools
Trackbacks are On
Transient Analysis tutorial Bharatkumar FLUENT 0 June 4, 2010 08:25
Transient analysis with turbFoam very high Courant nr hardy OpenFOAM Running, Solving & CFD 13 November 19, 2008 14:36
2-D airfoil transient analysis mike FLUENT 0 February 7, 2008 17:41
Transient analysis Andy F CFX 8 January 6, 2006 10:55
transient, parallel - problem with timestep Peter CFX 5 March 8, 2005 17:15
