July 7, 2004, 12:39 |
Need help in Compiled UDF.
I have some problem in using compiled UDF in FLUENT 6.1.22. I am using Mircosoft visual studio 6.0 as compiler. I try a simple UDF "Profile.c" from user manual. The information is as following. -------------------------- 1 file(s) copied. (system "move user_nt.udf libudf\ntx86\2ddp")0 (system "copy C:\FLUENT.INC\fluent6.1.22\src\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2ddp")() Profile1.c C:\FLUENT.INC\fluent6.1.22\cortex\src\dll.h(53) : fatal error C1083: Cannot open include file: 'stdarg.h': No such file or directory Done. ------------------------ I find the file 'stdarg.h' in the directory of "C:"\Program files\Microsoft Visual studio\VC98\Include" and browse it into the header file. Then I get the following information: -------------------------------------------- The system cannot find the file specified. 1 file(s) copied. (system "move user_nt.udf libudf\ntx86\2ddp")0 (system "copy C:\FLUENT.INC\fluent6.1.22\src\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2ddp")() Done. ------------------------------------------ When I load the library "libudf", I get the following information ----------------------------------------------------------- Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified. Error Object: () ------------------------------------ So What is wrong with this? Early reply will be appreciated. Thank you very much! Hp |
July 18, 2004, 07:34 |
Re: Need help in Compiled UDF.
Your compiler is not able to find the file 'stdarg.h'.
Probably it is not in a directory included in the Include path of the compiler. Check your compiler environment variables. P.S. I think you could find some more discussion and help on this topic in the forum. It seems an already discussed problem. Hi ap |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
I want to use pressure of 1 face in udf that compiled on other face | iman_1844 | Fluent UDF and Scheme Programming | 3 | June 10, 2010 12:55 |
Why udf can not be compiled in my pc? | Xinqiang | FLUENT | 0 | June 10, 2009 14:32 |
difference between udf compiled and udf interprete | chandra sekhar | FLUENT | 2 | April 11, 2006 00:04 |
how to quit compiled or interprited UDF | tian | FLUENT | 0 | April 8, 2003 23:53 |
